I can not see or make the connection between the two
no start no crank engine turn but will not start
I would check as follow
1. Check and make sure battery charged and terminal clean and tight
2. Check if you have an alarm system that may be causing the issue
3. Check starter relay on fender side by the battery
4. Check starter
5. If with automatic tranny check Neutral safety switch
6. If standard check clutch switch on the clutch paddle
7. If all check ok give wiring a good look and ignition switch too
SPONSORED LINKS
Friday, April 25th, 2008 AT 6:13 AM
