1995 Ford Escort Battery Idiot light...
1995 FORD ESCORT
100,000 MILES • 4 CYL • FWD • AUTOMATIC
SEANSCAR
The light came on a few days ago but the vehicle still runs. I'm assuming it's the alternator ($300 @ shop). Hoping it's the battery, I've hooked up the chargr for 2 hrs (12v/6amp) & the needle hasn't moved off 25%. Is the battery not taking the charge the problem or is it the $300 alternator job? Battery is a 'maxlife' thats 28 months old. (Southern climate).
Oct 6, 2008 at 3:39 PM
BMRFIXIT
  • 19,053 POSTS
I suspect the alternator
start engine check battery volts it should be over 12.5 v to 14.5v if alternator charging
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Oct 6, 2008 at 10:43 PM
