1994 Ford Escort STARTING THE CAR
SAILOR6535
  • 1994 FORD ESCORT
  • 4 CYL
  • 20,000 MILES
CAR STARTS PERFECT, DRIVE 10 MILES TO HOME. GET IN CAR AND IT WON'T START. DOES NOT TURN OVER OR MAKE ANY NOISE. JUMP START WON'T START IT. LATER GET IN CAR AND IT STARTS RIGHT UP. WHY
Saturday, October 10th, 2009 AT 11:27 PM
  • 109,755 POSTS
When this happens, I need you to check something. Have a helper turn the key to the start position while you check for voltage to the smaller wire on the starter. You should be getting 12+ volts. If you are, replace the starter. If not, let me know.
Monday, October 19th, 2009 AT 9:47 PM
