HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Escort
Engine
Symptoms
Stall at Idle
SPONSORED LINKS
1994 Ford Escort It dies
WRS4HIM
MEMBER
1994 FORD ESCORT
4 CYL
2WD
AUTOMATIC
56,000 MILES
I'm in park, idleing at walgreens and it died twice, Why?
Thursday, August 26th, 2010 AT 10:31 AM
MECHANIC
Fuel pump could be on its way out -check the fuel pressure to rule it out-if not try cleaning out the idle air control valve and see what happens
SPONSORED LINKS
Thursday, August 26th, 2010 AT 1:12 PM
WRS4HIM
MEMBER
Thanks
Friday, August 27th, 2010 AT 3:59 AM
Please
login
or
register
to post a reply.
Related Engine Stall At Idle Content
1995 Ford Escort Stalls When Idleing And Loses Power...
My Escort Wagon Stalls Often When Idling In Park, Neutral Or When I Pull Up To A Stop Light. This Has Been Going On For A Year. I Recently...
Asked by
JohnnieDinVa
1995
FORD ESCORT
GUIDE
Engine Stalls After Dead or New Battery
So you installed a new battery and now the engine stalls? You have done nothing wrong because believe it or not this is normal. The engine computer has a learning cycle...
2000 Ford Escort Won't Idle..
Dual Over Head Cam. Car Won't Idle And Will Die If I Let It. Runs Normal Over 2000 Rpms. Please Help. Thank You, Rob. P.S I'm Sorry...
Asked by
lipits
2000
FORD ESCORT
2002 Ford Escort Car Stalls When Braking
I Recently Had The Car ('02 Ford Zx2) In For Check Engine Light Code P0171 - Had A Vacuum Leak In The Hose Coming Off The Pcv Valve. This...
Asked by
coasterjen
2002
FORD ESCORT
2000 Ford Escort Dies At Idle
Engine Performance Problem 2000 Ford Escort Automatic My Car Dies Almost As Soon As I Take My Foot Off The Gas. It Doesn't Seem To...
Asked by
lettinggobabyg
2000
FORD ESCORT
1999 Ford Escort Stalling When Idle
Engine Mechanical Problem 1999 Ford Escort 90000 Miles Hello, My Car Has Been Stalling (or Just Basically Cuts Off) When I Idle...
Asked by
ash459
1999
FORD ESCORT
VIEW MORE
SPONSORED LINKS
Stalls at Idle
Spark Plug Replacement
Oil Life Reset Saturn Vue 2002-2007
Online car repair manuals
