They go thru and into the block. Remove the suspect bolts and check for damage, is the threads banged up/
try adding some high temp rtv sealent around them to stop.
Dependent on what is wrong you may have to replace the oil pan.
SPONSORED LINKS
Monday, September 22nd, 2008 AT 10:27 PM
