1993 Ford Escort brakes
1993 FORD ESCORT
LORENCE
Brakes problem
1993 Ford Escort 4 cyl Wheel Drive Type unknown Manual 134000 miles
Hi
I have had by brake pads and the calipers replaced on my escort but I still do not have brakes when you push down on the brake pedal the pedal goes all the way to the floor like there are no brakes could you please tell me what you think it could be?
Thank you, your time is greatly appreciated
Raynette
Mar 5, 2008 at 3:35 PM
BLACKOP555
  • CAR REPAIR CONTRIBUTOR
  • 10,386 POSTS
first thign is have someone pump on the brakes while you look for leaks coming out of the brake lines and brake components if nothign then you probably need to bleed all the wheels.
Mar 5, 2008 at 9:11 PM
