1990 Ford Escort Choking While Driving
Suggested Repair
Retrieve the EEC-IV trouble codes with a code reader or at an auto parts store and record the code numbers. Because the problem appears only after the engine is warm and while driving, with no black smoke, use the codes to check sensors that affect warm running, such as the coolant temperature and intake air temperature sensors.
Conversation Summary
The owner of a 1990 Ford Escort LX with 62,000 miles reports that after driving for a while the engine chokes, loses power, and the service engine light comes on, then briefly recovers and repeats. It does not stall, produces no black smoke, and runs fine at idle or when cold. The air filter, breather filter, and oil were already changed. The expert advised pulling EEC-IV codes and explained that a warm-only problem can point to a sensor whose readings become inaccurate as the engine warms.
