The tranny has had fluid change/service 3-4 months ago.
Thanks
Check transmission fluid level and condition with the engine running and top it off if low. If the fluid is fine, suspect slipping overdrive clutches or a torque converter that is not locking up. Also check the radiator coolant level when cold so the internal transmission cooler is not exposed and overheating the transmission.
The owner of a 1991 Ford Escort wagon reports highway RPM rising to about 3000 at 65-70 mph instead of about 2500-2650, with fuel economy dropping. The transmission was serviced recently. Advice was to verify fluid level and condition while running, consider slipping overdrive clutches or converter lockup failure, and confirm the radiator is full when cold so the transmission cooler stays covered. The check engine light is not on, and the owner noted the temperature gauge stays low except in traffic.
