1996 Ford Escort missing at low RPM under load
ALANL
  • 1996 FORD ESCORT
  • 4 CYL
  • FWD
  • MANUAL
  • 180,000 MILES
1996 Escort misses when accelerating between 1500 and 2500 rpm. No error codes are present. Car accelerates fine above 2500 rpm. Starts easily. Idles fine. New oxygen sensor. New fuel injectors and fuel filter. Engine rebuilt at 150000.
Saturday, April 10th, 2010 AT 8:55 PM
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Sunday, April 11th, 2010 AT 5:45 AM
