Need to know how to remove the spark plug boot from spark plug.
Mar 8, 2009 at 11:25 AM
OBXAUTOMEDIC
✓Experienced Mechanic
[quote:857403b93c="Starfighterii"]Engine Mechanical problem
2006 Ford Escape 4 cyl Two Wheel Drive Automatic 50768 miles
Need to know how to remove the spark plug boot from spark plug.[/quote:857403b93c]
Once you pull the coil off the top of the boot it should pull right off.
Mar 8, 2009 at 11:37 AM
STARFIGHTERII
MEMBER
The boots were froze in the holes I took the back of a chisel handle placed it into the spark plug hole and spun it a few time it broke free the boot and then it came out with out a hitch but thanks for the help the boot is what had me nervous thought ford had come up with some thing new I used to build racing engines but have not worked on an engine for 22 years they are simular but their are differences that I am a bit squimish about. thanks again.
Mar 9, 2009 at 10:48 AM
