2004 Ford Escape
EMANUEL LOGAN
  • 2004 FORD ESCAPE
  • 6 CYL
  • FWD
  • 75,190 MILES
I was driving and when I parked and turned the truck of then I got back in and tryed to start it back up again it would'nt start what could it be
Wednesday, January 27th, 2010 AT 12:07 PM
Pick your symptoms:
Cranks but no start condition:
Get a helper disconnect a spark plug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark?
This guide will help us
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems
with compression and valves opening and closing at the wrong time/broken or jumped timing
belt/chain.
Wednesday, August 12th, 2020 AT 1:32 PM
