2002 Ford Escape Road noise
2002 FORD ESCAPE
81,000 MILES • 6 CYL • 4WD • AUTOMATIC
RPFAU
A year ago I had an alignment and the rt wheel bearing assy repalced, there was a lot of road noise. A year later the tire/road noise is loud as ever. I just rotated the tires and at 55 mph and higher the noise get very loud. There appears to be no abnormal tire wear and I have Continentel tires. What might I check? Richard
Apr 6, 2009 at 5:59 AM
TECHMAN1
  • 82 POSTS
[quote:7b5faee7c5="rpfau"]Tires and Wheels problem
2002 Ford Escape 6 cyl Four Wheel Drive Automatic 81000 miles
A year ago I had an alignment and the rt wheel bearing assy repalced, there was a lot of road noise. A year later the tire/road noise is loud as ever. I just rotated the tires and at 55 mph and higher the noise get very loud. There appears to be no abnormal tire wear and I have Continentel tires. What might I check? Richard[/quote:7b5faee7c5] On my 2002 Escape, it was a rear wheel bearing. If you jack it up off the ground and turn the wheel by hand, you should be able to feel which one is bad. I got the bearing on Ebay new for $30, but it was a terrible 7 hour chore to replace it because of the way it is assembled.
May 19, 2009 at 9:46 PM
