I have a fuel Issue with my E-150 5.0l. It was starting and running just fine until some days ago and then had the problem to not start without starting fluid. After I sprayed starting fluid in it will run about ten minutes again. But when I come to a stop at an Intersection the motor will take no throttle and shut off. I came to the conclusion it is either the fuel pump, fuel filter or fuel pressure regulator. The fuel filter was not changed for a long time but will be changed soon, can just a clogged fuel filter be the problem or is it probably worse than that? Also, I need to mention that the car was still standing for about four months until I was starting it again, maybe there was some rust in the tank so it clogged the fuel filter even more?
Jul 23, 2018 at 11:17 AM
