1994 Ford E-150 Timing Chain Chatter
ROBSVAN
HI own a 1994 E-150 Econoline conversion van with a 5.0 liter engine. This vehicle has 99,440 miles on it. When taking off there is a brief chattering sound that occurs that can also be heard as the vehicle shifts into overdrive and occasionally while maintaining speed on level road. could this be the timing chain rubbing against the timing cover?
Sep 21, 2006 at 1:27 PM
ROBSVAN
[quote:d7d1cc55ab="robsvan"]I own a 1994 E-150 Econoline conversion van with a 5.0 liter engine. This vehicle has 99,440 miles on it. When taking off there is a brief chattering sound that occurs that can also be heard as the vehicle shifts into overdrive and occasionally while maintaining speed on a level road. Could this be the timing chain rubbing against the timing cover?[/quote:d7d1cc55ab]
Sep 21, 2006 at 1:35 PM
NOS
  • 320 POSTS
it is possible. the best way to tell is take a peice of rubber hose about 3 foot long put the head of a three inch bolt in on end of the hose. try not to touch anything else set the bolt on the case with the engine running and put the other end to you earyou should be able to hear what it is doing(NOS) 8)
Sep 23, 2006 at 8:28 AM
ROBSVAN
Thank you for that helpful hint. I have used the hose with a bolt inserted at one end. I can definately hear the timing chain rubbing against the timing cover and now know that the timing chain is definately in need of replacement. Since this replacement is necessary, is there anything else that you would suggest be checked for while that part of the engine has been dismantled for the procedure?
Sep 23, 2006 at 3:17 PM
NOS
  • 320 POSTS
there isn't much else to see there. i would change the water pump cause it will save you in the long run on having to do it later. just take you time thoes bolts rust up real bad and they are known to break. whem going back together use a antisize compound on the cleaned bolts.(NOS) 8) just make sure to send a post to BON and Ken thanking them so they can keep site open.
Sep 23, 2006 at 4:11 PM
Suggested Repair
Replace the timing chain. While the front of the engine is apart, also replace the water pump. Work carefully because the bolts rust badly and can break; clean them and apply anti-seize during reassembly.
Conversation Summary
The owner of a 1994 Ford E-150 with a 5.0L engine reported brief chattering during takeoff, when shifting into overdrive, and occasionally at steady speed, and asked whether the timing chain was rubbing the timing cover. An expert suggested listening with a hose and bolt. The owner confirmed the chain was rubbing the cover, and the expert recommended replacing the timing chain, changing the water pump while access was open, and using anti-seize on the cleaned bolts.
