2003 Ford E-Series Van how to determine timing chain slippa
2003 FORD E-SERIES VAN
188,000 MILES • 6 CYL • 2WD • AUTOMATIC
CLAY CUPIT
My van is running a little rough, and sounds like I got a piston or 2 kissing my valves. How do I determine if I have a Timing Chain Slippage or a valve train failure ?
Feb 5, 2010 at 10:26 AM
RACEFAN966
  • 5,029 POSTS
Well first I need some info before I can help. What 6cyl do you have? Get back to me with that and we will go from there.
Feb 6, 2010 at 12:43 AM
CLAY CUPIT
Sorry about that, It is a V6 4.2 and does not have DOHC''s.
Started it again, just sounds like a diesel, but still runs.
How do I detemine Timing time slippage or major valve train failure ?
Feb 6, 2010 at 3:10 AM
RACEFAN966
  • 5,029 POSTS
Ok what you would have to do is bring it up to number 1 compression stroke and then check to see if the timing mark on the harmonic is at 0.
Feb 8, 2010 at 8:03 AM
