1999 Ford E-150 Battery Dies Sitting
JACKIE2467
I own a ford 1999 e150 van. Recently our van would not start we charged the battery and it worked fine for a few days then dead again. We replaced the battery and it worked fine for 5 days then dead again we jump started it and it worked fine for 1 day then dead again. Could it be the alternator or it there more likely a electric draw on the battery from some source. The ban never dies while driving and the volt meter indicates that the battery is charging while driving. it always goes dead just sitting in driveway.
Oct 24, 2007 at 1:22 AM
  • 75,988 POSTS
Disconnect the postive cable put the test lite between cable and battey postive post, Is the test lit-if so you got a short circuit in the electrical system-start removing fuses/relays/connectors the one that eliminates the light is the problem circuit.
Oct 26, 2007 at 8:25 PM
Suggested Repair
Disconnect the positive battery cable and place a test light between the cable and the positive post. If the light stays on, a parasitic draw is present. Remove fuses, relays, and connectors one at a time until the light goes out to identify the circuit causing the drain.
Conversation Summary
The owner of a 1999 Ford E-150 says the battery goes dead after the van sits, even after charging or replacing it, but it does not die while driving and the voltmeter shows charging. The expert recommends a parasitic-draw test with a test light and isolating the circuit by removing fuses, relays, and connectors.
