1992 Ford F-150 Battery Light Dies
CLAYPOOL
I have a 1992 Ford F150 with the 4.9 and 117,000 miles on it. I just replaced the alternator and while test driving the battery light came on and the truck started to die down. I was able to keep it running by feathering the accelerator, but when i would turn on the lights the truck would die down and when i turned them off it would rev back to normal. What could this be?
Oct 4, 2007 at 6:05 AM
BLACKOP555
  • 10,386 POSTS
make sure belt is not slipping on altenator. or the cables are all secure and snug and going ot the right place. if that is all tested ok then have the alternator tested at a auto parts store.
Oct 5, 2007 at 3:37 PM
Suggested Repair
Check that the alternator belt is not slipping and that the cables are secure, snug, and connected to the correct places. If those checks are fine, have the alternator tested at an auto parts store.
Conversation Summary
The owner of a 1992 Ford F-150 with a 4.9 engine and 117,000 miles replaced the alternator, then the battery light came on and the engine died down, especially with the lights on. An expert advised checking for a slipping belt and secure, correctly routed cables, then testing the alternator if those checks are fine.
