2004 Ford F150 CHARGING SYSTEM
2004 FORD F-150
JAY'S JUNK
Electrical problem
2004 Ford F150 V8 Four Wheel Drive Automatic
DRIVING TO WORK,ALL GAUGES FLAT LINED AS IF THE KEY WAS OFF.HAD NO POWER ANYWHERE,POWER WINDOWS DIDN'T WORK,RADIO WENT OFF,A/C WENT OFF,ALTHOUGH THE FAN STAYED ON.ALSO HORRIBLE GRINDING NOISE FOR MINUTE OR SO,THEN STOPPED.
ENGINE DIDN'T MISS A LICK,RAN SMOOTH TILL I TURNED OFF THE KEY.THEN WOULDN'T START,LIKE DEAD BATTERY.....JUMPED TRUCK,AND LET CHARGE ABOUT 5 MINUTES,WHILE STILL HOOKED TO JUMPER CABLES,DROVE HOME 12 MILES OR SO,WITHOUT ANY TROUBLE...
AT HOME ODC CODES, P0117,P0119,P0622,P2077,P2106. ALTINATOR TESTED GOOD,BATTERY TESTED GOOD,ALL RELAYS ARE GOOD...WHAT ELSE CAN I DO,DO YOU KNOW WHAT THE PROBLEM IS ???
May 31, 2010 at 12:32 PM
  • 110,244 POSTS
the 117 and 119 both deal with the coolant temp sensor which wouldn't have caused the problem. PO622 deals with a Generator Field "F" Control Circuit Malfunction which is related to the alt, but still I wouldn't tie that together with everything dieing. I can't find a listing for the 2K codes.
When you jumped the truck, did everything still continue not to work?
May 31, 2010 at 3:31 PM
