Installation of new key cylinder on 1995 gas ford van
MJCONCRETE
My question is that before replacing the key cylinder because it being very sloppy and would start the van but not shut it off. Now after replacing the key cylinder that also came with a key the van will not start or shut off. Is there a code or something I need to match woth the new part and the van? If there is anyone that knows whats up please help and thanks in advance! Hope I can help in the future.
Oct 7, 2007 at 2:54 AM
BMRFIXIT
  • 19,053 POSTS
[quote:bab010eeb9="mjconcrete"]My question is that before replacing the key cylinder because it being very sloppy and would start the van but not shut it off. Now after replacing the key cylinder that also came with a key the van will not start or shut off. Is there a code or something I need to match woth the new part and the van? If there is anyone that knows whats up please help and thanks in advance! Hope I can help in the future.[/quote:bab010eeb9]
If it was starting with the key but no shutting off
How were you shutting it off?
On 95 no key codes that I can think of for the ford van
Does it crank but no start after the replacement of the cylinder
Or nothing
let us know
Oct 7, 2007 at 3:03 AM
MJCONCRETE
Before replacing the key cylinder I had to pull off the coil wire to shut it off oh yah thats great :) So now after putting in the new cylinder it turns ike it should from off acceseries then start but the van stays AND acts like it staying in acceseries Radio and blower stays on even when the key is out if You have any Idea please reply. Every other cylinder I replaced was only a 10 min job I guess not this one Thanks for your help
Oct 7, 2007 at 6:20 AM
BMRFIXIT
  • 19,053 POSTS
[quote:80c750f1b5="mjconcrete"]Before replacing the key cylinder I had to pull off the coil wire to shut it off oh yah thats great :) So now after putting in the new cylinder it turns ike it should from off acceseries then start but the van stays AND acts like it staying in acceseries Radio and blower stays on even when the key is out if You have any Idea please reply. Every other cylinder I replaced was only a 10 min job I guess not this one Thanks for your help[/quote:80c750f1b5]
You may have a broken link
When turning the key you are pushing and pulling a rod that link the key to the ignition switch
You can pull down the steering column and remove the ignition switch and activate the starter manually by the switch w/o the key.
Or rotate the key while watching the link movement
Let us know
Oct 7, 2007 at 11:17 AM
