Window motor fails in the down position. Not original motor, it is about 4 years old. When removed it works perfectly. Has it been improperly installed or is the motor bad? Is there an overload device that may be faulty? The window was not subjected to abuse or over use before failure. Window moves freely in tracks and switches either both work or neither works, implying the switches are good.
May 23, 2008 at 12:18 AM
