1982 Ford E-Series Van dash/right signal turn indicator lig
JUDSONERWIN
  • 1982 FORD E-SERIES VAN
  • 6 CYL
  • MANUAL
  • 18,500 MILES
Although my right side turn signal lights work, the right side dash light and right side dash turn indicator light and defroster fan do not work.
Thursday, July 23rd, 2009 AT 5:29 PM
HIPPO800
  • 29 POSTS
When the heater malfunctions it is usually corrosion in the fuse panel contacts.
Wrap fine sandpaper around a small hex key.
Slide it back and forth in the heater fuse contacts.
Check the fuse with an ohm meter too.
Use a dab of dielectric grease on the fuse clamps.
Clean the heater resistor terminals with fine sandpaper and clean the corrosion off the back supports for the resistor coils.
Check resistor with ohm meter as well.
The turn signals wires sometimes have poor grounds.
Mine work fine on my 82 van.
Dielectric grease on all electrical connections is wonderful.
Wednesday, February 3rd, 2010 AT 8:36 PM
