92 crown victoria brake lights
TOLLITUDE
so my brake lights won't light up. both driver side and passenger and rear windshield lights. i've checked fuses and bulbs. all look okay. i found some advice to Check the brake light switch on the brake pedal linkage. how do i do this and how do i know i'm doing it right? please help.
thanks
1992 crown victoria 169000 mi. 4.6l v8
Aug 19, 2007 at 12:52 PM
HOLISE
  • 6 POSTS
The brake light switch is at the top of your brake pedal assembly. The task is not hard to do, just hard to explain. Your best bet is to get a repair manuel, you can get one at an auto parts store for between 15-20 dollars, the one I have shows a good detailed blow-up drawing of everything.
good luck,
holise
[quote:21c270692f="tollitude"]so my brake lights won't light up. both driver side and passenger and rear windshield lights. i've checked fuses and bulbs. all look okay. i found some advice to Check the brake light switch on the brake pedal linkage. how do i do this and how do i know i'm doing it right? please help.
thanks
1992 crown victoria 169000 mi. 4.6l v8[/quote:21c270692f]
Aug 22, 2007 at 3:30 AM
