My Heater is not working
STEVE W.
  • 13,573 POSTS
Sounds like blend door control failure. The problem is that one book says that it's a cable controlled item, another says it's electronic even with a manual control.
BUT because you say you have a slider I'm going with it being a cable.
From reading the various items it appears that you might be able to reach the end of the cable that moves the blend door if you removed the glove box and reach up to the top of the heater plenum and find the cable. Then you could tell if it's that end or the control head end by moving the lever as you feel the cable. If the cable moves but the lever doesn't it's the adjuster clip that's failed. If the cable doesn't move it's in the control head. That requires you to drop the steering column and remove the dash trim panels to remove the control.
Wednesday, January 13th, 2021 AT 12:28 PM (Merged)
SAYPEEWEE
  • 1991 FORD CROWN VICTORIA
  • V8
  • 93,000 MILES
The heater just quit working out of the blue. It blows cold air like air conditioning all the time. I think its the controls but dont know how to check it.
  • 31,937 POSTS
Hi there,
with the engine hot and the heater controls on hot, feel the two heater hoses going into the cabin, they both should be about the same Temp, if not the heater tap is not on, check this first.
Mark (mhpautos)
OLMANATEE
  • FORD CROWN VICTORIA
97 Ford Crown Victoria police interceptor, 68k, yes only 68k miles, 4.6liter V8
Driving today, 55-60 degrees, no heat in car, and I noticed temp gauge in red. Stopped, turned off for 5 minutes, started, still no heat, temp rose rapidly.
Car has been running GREAT with no symptoms until today. No leaks, no water anywhere, overflow bottle full. Retired police car, officers car, low miles, good maintenance. I've owned it 4 months, and this hasn't been "building" as a problem, it just appeared all of a sudden. Everyone I talked too before I bought it told me that the Crown vic P71 was basically bulletproof from repairs, so I am concerned this is a major thing. Help?
TAURUSWHEEL
  • 718 POSTS
Change the thermostat to start with, those symptoms are classic stuck closed thermostat, hopefully that'll help
MIKE H R
  • 3,094 POSTS
I would say it is the thermastat, the lack of heat makes me think diferent, how is the fluid level? Check the belts.
