My Heater is not working
2004 FORD CROWN VICTORIA
72,000 MILES • V8 • 2WD • AUTOMATIC
EZRIDER
The heater on vehicle is not working?
Nov 15, 2009 at 10:00 AM
WAY2OLD
  • 195 POSTS
A little more information is needed. Where does the temperature gauge stay? this guide can help us fix it
https://www.2carpros.com/articles/car-heater-not-working
Nov 16, 2009 at 9:51 AM
EZRIDER
Yes the radiator is working, radiator cap is ok, the radiator is flowing, the coolant is ok too and the temperature is where it should be, normal. The "door", I'm not too sure about that.
Nov 16, 2009 at 10:44 AM
WAY2OLD
  • 195 POSTS
Park the car in a quiet location. Shut all doors, turn the key on, wait for all dinging to stop. Then turn the heat selector from cold to hot and see if you can hear a litthe motor running followed by a dull thud. Then try it from hot to cold. If it does not make a noise, the actuator is bad. If it makes a noise and no "thud", the door is broken or the gears are stripped in actuator.
Nov 16, 2009 at 10:31 PM
SKRIMSKI
Heater problem
2002 Ford Crown Victoria V8 Two Wheel Drive Automatic
I Heater and AC will not come on. Checked and replaced relay in engine compartment, all fuses checked, blower motor works when jumped straight from 12 volt system. lights work in panel shows automatic with set temperature and fan light, but no blower motor or condensor movement.
Jan 13, 2021 at 4:27 AM (Merged)
WRENCHTECH
  • 20,761 POSTS
Since you have an auto temp control system, you likely have a bad Blower Speed Control Module. They fail quite often. It's located in the blower housing, right near the blower motor.
2CP-ARCHIVES
  • 4,540 POSTS
When i turn the heater on it doesnt warm up. It continues to blow cold air. I was wondering if there is a quick fix i could possibly try cause i dont have time to take it to the shop right now
BLAZE45
  • 380 POSTS
It is probably 1 of 2 things. Your blend door is stick open/closed or your valve that lets warm water into the heater core is broke. There should be 2 lines that go into the heater core into the firewall of the car. The valve should be right in that area or just on the other side of the firewall. You can manually check the valve and see if it is causing the issue. Your heater core could be clogged as well though.
Good luck.
TAXIMAN805
I have a 2001 Ford Crown Victoria with climate control, the heater stopped working but the air conditioner still works, what is wrong with the heater or how can I fix it? If the air conditioner is NOT on it gets hot in the car, as if the heat was on but it’s not on. The air conditioner works just fine but no heat unless you turn OF the climate control. Can you help me?
FIXITMR
  • 9,990 POSTS
4hundred thirty thousand miles? you mean heat dont blow?
TAXIMAN805
Yes the heat does not blow but the ac blows just fine
TAXIMAN805
Yes and it dose have 4 hundred and 30tousand miles Original engine
  • 110,244 POSTS
Check the blend door if it feels like heat is on all the time. That is a lot of miles. Does it still run well for you?
FIXITMR
  • 9,990 POSTS
if it's getting heat but not blowing check your underhood wiring on firewall pass side to fan / resistor/ speed control. if nuthin looks burnt melted try unplugging and re-plugging. could also be bad speed control or resistor.
FAYEFAYE1
heater is blowing cold air changed the thermostat but didn['t help
  • 31,937 POSTS
First thing to check is that both heater hoses are hot to touch with the engine at normal operating temp, check that first and let me know what you find.
KSTRINGER
Car has a sound of coolant inside passenger side under dash. Coolant does not leak on floor. Heater blows hot, extremely hot. Air conditioner also blows extremely hot. AC freon level is good.
  • 110,244 POSTS
What you hear is coolant entering the heater core. It can be caused by low coolant or an air pocket in the system that needs bleed.
AMY RUSHING-ADAMS
Heater blows cold air through all vents.
PATENTED_REPAIR_PRO
  • 1,853 POSTS
First thing to do is check your engine coolant level when the engine is cold so you do not burn yourself, unless of course you have an overflow jug that you can just check, because if the engine coolant level is low, the heater core will not have hot coolant flowing through it, it will have just lukewarm air which might just feel cool by the time the blower motor blows air across the heater core.
Jan 13, 2021 at 4:28 AM (Merged)
JUNE BARKER
The blower works because it blows cold air but no warm air. The slider from blue which is cold to red which is warm makes no noise when moving like not connected. I am freezing.
STEVE W.
  • 15,348 POSTS
Sounds like blend door control failure. The problem is that one book says that it's a cable controlled item, another says it's electronic even with a manual control.
BUT because you say you have a slider I'm going with it being a cable.
From reading the various items it appears that you might be able to reach the end of the cable that moves the blend door if you removed the glove box and reach up to the top of the heater plenum and find the cable. Then you could tell if it's that end or the control head end by moving the lever as you feel the cable. If the cable moves but the lever doesn't it's the adjuster clip that's failed. If the cable doesn't move it's in the control head. That requires you to drop the steering column and remove the dash trim panels to remove the control.
SAYPEEWEE
The heater just quit working out of the blue. It blows cold air like air conditioning all the time. I think its the controls but dont know how to check it.
  • 31,937 POSTS
Hi there,
with the engine hot and the heater controls on hot, feel the two heater hoses going into the cabin, they both should be about the same Temp, if not the heater tap is not on, check this first.
mark (mhpautos)
OLMANATEE
97 Ford Crown Victoria police interceptor, 68k , yes only 68k miles, 4.6liter V8
Driving today, 55-60 degrees, no heat in car, and I noticed temp gauge in red. Stopped, turned off for 5 minutes, started, still no heat, temp rose rapidly.
Car has been running GREAT with no symptoms until today. No leaks, no water anywhere, overflow bottle full. Retired police car, officers car, low miles, good maintenance. I've owned it 4 months, and this hasn't been "building" as a problem, it just appeared all of a sudden. Everyone I talked too before I bought it told me that the Crown vic P71 was basically bulletproof from repairs, so I am concerned this is a major thing. Help?!?!?
TAURUSWHEEL
  • 718 POSTS
Change the thermostat to start with, those symptoms are classic stuck closed thermostat,, hopefully that'll help
MIKE H R
  • 3,094 POSTS
i would say it is the thermastat, the lack of heat makes me think diferent, how is the fluid level? check the belts,
