Not cranking over
MRCROWNVIC
Thanks for all the help.
Tuesday, January 22nd, 2019 AT 8:03 PM (Merged)
  • 109,885 POSTS
If you have fuel in the tank, chances are the fuel pump is bad. You will need to check and make sure it is getting power. Let me know what you find.
WAKESK888
  • 21 POSTS
I got it fixed. It was the fuel pump
  • 109,885 POSTS
Glad you got it fixed. Based on your description, that is what it sounded like.
Take care and let us know if you have questions in the future.
MDJENKS36
  • 2002 FORD CROWN VICTORIA
Car turns over but won't start sometime act as if wants to start
  • 109,885 POSTS
Have you checked for spark and fuel to the engine?
LADIIE
  • 2000 FORD CROWN VICTORIA
2000 Ford Crown Victoria V8 156000 miles
I have a Ford Corwn Vic 2000 police model, I drove the car the day prev and woke up the next morning to get ready for work and the car will not start. It has fuel, we`ve checked the fuels and they are fine. What can be the matter with the car?
Tuesday, January 22nd, 2019 AT 8:04 PM (Merged)
BMRFIXIT
  • 19,053 POSTS
Does it crank put no start
have fuel did you check for fuel pressure
do you have spark
if not sure how to do all this check our video collection in the at home page
REEBA
  • 2004 FORD CROWN VICTORIA
Electrical problem
2004 Ford Crown Victoria V8 Automatic 98000 miles
Starter Ok. This is a ford crown vic interceptor. Can start car by crossing the terminals on starter motor. I've replaced ignition switch. Are there any fuses I missed checking? Checked main fuse box. There are black fuses that you can't read. Could this be the problem or is it something else?
  • 109,885 POSTS
Hi:
have you checked the starter relay?
