1992 Ford Crown Victoria Engine will not turn over
LANCE43
  • 1992 FORD CROWN VICTORIA
  • V8
  • 182,000 MILES
My car has been running fine. I left home for the store and when I came out the car would not start. I tried to jump start it but that did not work. I would just hear the solenoid click everytime I turned the ingnition to crank. I took the battery connectors off and hooked the jumper cables to the car jumping mine, but just got a clicking from the solenoid. With my battery connected I have all electrical power. When I turn on the headlights they do not dim. Electric windows work, radio works, dome lights work.
Wednesday, September 30th, 2009 AT 10:46 PM
SERVICE WRITER
  • 9,123 POSTS
Check for power to the starter motor, If good, try rapping on the starter to see if it then starts. Jarring a starter that is going bad will sometimes cause it to temporarily work. Sounds like the starter is bad.
Thursday, October 1st, 2009 AT 5:15 AM
LANCE43
  • 14 POSTS
Thank you for your response. The voltage is good and I tapped it with a hammer and it started.
Thursday, October 1st, 2009 AT 2:50 PM
SERVICE WRITER
  • 9,123 POSTS
Buy a good one!
Napa premium or usa brand are the two that I have had good luck with. Cheapies get you stranded.
Thursday, October 1st, 2009 AT 3:57 PM
