1998 Ford Crown Victoria police car problems
78CHEVY
  • 1998 FORD CROWN VICTORIA
1998 Ford Crown Victoria V8 Two Wheel Drive Automatic
we have a 1998 ford crown vic police car, we were driving the car and it kept stalling out and then it dies and wont start back up. The engine just spins over. The car does start with starting fluid sprayed in the air breather. Is it possible this could just be a fuse problem. I dont know what is wrong with it. Please answer.
Sunday, July 5th, 2009 AT 9:09 PM
WAY2OLD
  • 195 POSTS
If the car starts on starter fluid, it is definately a fuel relalated problem. May be a blown fuse, bad relay, bad wiring or a fuel pumo that is on its way out.
Tuesday, July 14th, 2009 AT 7:32 PM
DD66
Most likely culprit is the fuel pump cut off switch in the trunk on left side. It is desgined to trip out if car is hit in collision, but sometimes it works loose. Reset it and try to start it. If the switch seems loose cross the terminals and try to start it. If car starts replace the switch.
Monday, August 17th, 2009 AT 11:14 AM
Related Engine Not Running Content
