1998 Ford Crown Victoria do not start
TRAFFICCONTROL
  • 1998 FORD CROWN VICTORIA
  • V8
  • 98,000 MILES
My 1998 ford crown victoria do not start fuel pomp got replace putting gas in theair intake gived me explotions (ther's spark ok) so has to be with the fuel filter or the fuel injectors scanner give err reading no codes (?) Just to clearify I put a gallon of gas just in case that the fuel gadge may gone bad without me not knowing 1/4 of a tank
Tuesday, September 23rd, 2008 AT 3:45 AM
Check the fuel pressue to rule out the fuel filter and pump if okay check for injection pulses
Tuesday, September 23rd, 2008 AT 4:08 AM
TRAFFICCONTROL
The pump checked ok, the filter replace was old anyways fuel injectors show power in one terminal conector ground at the other.
I desconect the fitting to the fuel reel comming from gas tank put a plastic bottle open the ignition and collected the gas so what can be the next step to check?
Wednesday, September 24th, 2008 AT 12:15 AM
What is the actual fuel pressure reading?
Check for spark
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, cam and crank sensors-
Wednesday, September 24th, 2008 AT 1:39 PM
Related Engine Not Running Content
