1997 Ford Crown Victoria Sensors
160,000 MILES • V8 • 2WD • AUTOMATIC
BOOG
What is the job of the mass air flow sensor. I already replaced two oxygen sensor and codes P171 and P174 keeps showing up. Do or should I replace the mass air flow sensor and if so what is the main purpose???
Aug 15, 2008 at 6:12 AM
MERLIN2021
  • 17,250 POSTS
Mass Airflow (MAF) Sensor MAF sensor uses a hot wire sensing element to measure amount of air entering the engine. Air passing over the hot wire causes it to cool. The hot wire is maintained at 392°F (200°C) above ambient temperature, as measure by a constant cold wire. See Fig. 2 . The current required to maintain hot wire operating temperature is proportional to the intake air mass. The PCM calculates the fuel injector pulse width in order to provide the desired air/fuel ratio. Fig. 2: Cross-Sectional View Of MAF Sensor Courtesy of FORD MOTOR CO. © 2007 Mitchell Repair Information Co., LLC. Page 1 of 1 THEORY/OPERATION -1997 Ford Crown Victoria 8/15/2008 http://www.ondemand5.com/mric/common/asp/printart.aspx If the MAF malfunctions it CAN affect mixture, and give these codes, but so can a vacuum leak.
Aug 15, 2008 at 6:43 AM
