1996 Ford Crown Victoria where is computor located
1996 FORD CROWN VICTORIA
150,000 MILES • V8 • 2WD • AUTOMATIC
JBOND0023
car will run if you poor gas in intake, i have replaced fuel pump and pressure regulater and mass air flow censer. the car ran for a few minutes when i replaced mas then quit. could it be the computor and where is it located
May 15, 2010 at 1:59 AM
  • 31,937 POSTS
HI there, ECU's are very reliable and hardly ever give any problems, have you checked for any unresolved fault codes, the computer is behind left side of dash on left side of fire wall.
mark (mhpautos)
May 15, 2010 at 2:36 AM
JBOND0023
fault codes read lean fuel in bank 1 and 2, what does that mean
May 15, 2010 at 12:12 PM
  • 31,937 POSTS
Hi there, this can indicate a vacuum leak, look here first.
mark.
May 15, 2010 at 8:50 PM
JBOND0023
[quote:80c747c4db="jbond0023"]fault codes read lean fuel in bank 1 and 2, what does that mean[/quote:80c747c4db] also, I checked injecters and fuel pressure, everything is working, When I changed the mass air flow the car ran for about 15 minutes on its own then quit. If you poor gas in plentum it will run til gas is gone, I have tried about everything.
May 17, 2010 at 2:13 AM
