2000 Ford Crown Victoria MASS AIR FLOW SENSOR ,SPARK PLUGS
2000 FORD CROWN VICTORIA
100,000 MILES • 6 CYL • 2WD • AUTOMATIC
ZULU
IS IT HARD TO CHANGE,WHERE IS IT AT?HOW MUCH DO IT COST AT A SHOP ? IS THE SPARK PLUGS HARD TO CHANGE,ABOUT HOW MUCH WILL IT COST IN A SOHP.DO YOU HAVE PICTURES OF ABOVE.THANK YOU
Jan 14, 2009 at 6:25 AM
BILLYMAC
  • 2,204 POSTS
i assume you have a 4.6 reng the mass airflow is located in the big breather hose comeing from the throttle body.it has 2 clamps and an elec plug. the cost is around 200.00 spark plugs are not easy on this car and to have a shop do it you would be looking at about 150 labor plus 4o.00 parts good luck billymac
Jan 14, 2009 at 11:07 AM
