1995 Ford Crown Victoria motor info
1995 FORD CROWN VICTORIA
20,000 MILES • V8 • 2WD • AUTOMATIC
KITTYLUV1
what would happen if the roker arm falls off and over head cam and how do u knw when u have a burnt vaule
Aug 31, 2010 at 10:46 AM
  • 110,244 POSTS
Both would cause a missfire. As far as the burnt valve, if it is an intake valve, you may hear a popping through the intake. Exhaust would be through the exhaust. NOTE: Low engine compression in that cylender would also identify a burnt valve. A rocker arm wouldn't affect the compression.
Sep 3, 2010 at 12:38 AM
