1995 Ford Crown Victoria
JLMMILLER3
  • 1995 FORD CROWN VICTORIA
hey my name is chris I wanted to know could I get a picture to show me where the brake booster vacuum hoe connect at on the engine cause I have no breaks after head gasket repair
Sunday, October 3rd, 2010 AT 4:37 PM
  • 110,053 POSTS
Chris:
I don't have a picture, but there will only be one place on the intake that takes a hose that large. Check that and let me know if you find it.
Sunday, October 3rd, 2010 AT 11:01 PM
WAY2OLD
  • 195 POSTS
If the car will start and idle, the vacuum hose is attached to the intake and the check valve is working. So if the car runs fairly well, the brake hose is out of the brake booster.
Monday, October 4th, 2010 AT 6:27 PM
JLMMILLER3
I found the problem. I left the hose off the intake. I have another question. Do u know why my lifters r tapping could it still be water in them. What do u suggest I do?
Monday, October 4th, 2010 AT 8:05 PM
  • 110,053 POSTS
I will assume that coolant got into the engine. You can try changing the oil and using an additive to see if that helps. However, they may have been damaged if too much water got to them and collapsing.
Tuesday, October 5th, 2010 AT 7:13 AM
