1989 Ford Crown Victoria power to the ignition
1989 FORD CROWN VICTORIA
144,908 MILES • V8 • 2WD • AUTOMATIC
89ASSISSIN
i have replaced the solenoid on the firewall of the car, the battery has been replaced the ignition lock key and cylinder and the igniton switch has been replaced but i still dont have any power inside the vehicle or i cant crank from the ignition
Oct 12, 2008 at 1:17 AM
MERLIN2021
  • 17,250 POSTS
Bad Negative battery cable, bad fusible link at the solinoid you just replaced, or blown main fuse at the power distribution box under the hood, follow the cable from the alternator , it goes right to the main fuse.
Oct 12, 2008 at 1:46 AM
