i have a 1995 ford contour and it doesn't get any spark to the spark plugs and i would like to know wht u think the problem could be?
Jun 2, 2006 at 10:52 AM
On the 1995 Contour 2.5 with fuel but no spark and no check engine light, replace the ignition module if the vehicle uses one. If spark is controlled by the processor, test and replace the crankshaft position sensor.
The owner of a 1995 Ford Contour 2.5 said it would not start because the spark plugs received no spark, although it was getting fuel and the check engine light was not believed to be on. The expert said some 1995 models use an ignition module that should be replaced, while others have processor-controlled spark, in which case the crankshaft sensor is the most likely cause. A later comment about a 1992 Ford Taurus with a similar no-spark issue received no location or repair guidance.
