1998 Ford Contour No Spark
DAWN39JONESBORO
  • 6 POSTS
i have checked everything on my car from fuel filter and the car is getting gas could the coil be bad or not generating enough power for it to hit? I am also on my third battery the last two where bad, but i believe this one is ok. I have checked the timing belt intact and tight, i don't have an air filter in right now, but i have checked the spark plugs and spark plug wires my neighbor said that when he checked the coil it should a clear spark not a blue one and it should be blue is this correct?
Nov 16, 2006 at 7:22 AM
BRUCE HUNT
  • 3,754 POSTS
The spark should be blue and one key is that the timing belt can be fine but there might be a camshaft position sensor that has failed. This item if failing is an important part of the spark timing process. The coil could be failing and there are tests for that.
Nov 16, 2006 at 12:20 PM
Suggested Repair
Confirm the spark is blue, then test the ignition coil and check the camshaft position sensor, which can fail and disrupt spark timing even if the timing belt is intact and tight.
Conversation Summary
The owner of a 1998 Ford Contour says the engine is getting fuel, the timing belt is intact and tight, and the battery, spark plugs, and plug wires have been checked, but the engine still will not hit. A neighbor disagreed about whether coil spark should be clear or blue. The expert said spark should be blue, noted the coil may be failing and can be tested, and suggested a failed camshaft position sensor as a possible cause of incorrect spark timing.
