1996 Ford Contour oil in spark plugs
ANGELINA510092
  • 1996 FORD CONTOUR
  • 4 CYL
  • 200 MILES
There is oil in spark plug chamber and is stalling out. Have any ideas what could cause this?
Saturday, July 24th, 2010 AT 9:36 PM
  • 109,878 POSTS
If the oil is on the outside of the engine around the pluge, chances are the valve cover is leaking. As far as the engine dieing on you, has the check engine light come on? When does it happen? Have you checked fuel pump pressure?
Tuesday, August 10th, 2010 AT 1:17 AM
