1995 Ford Contour Speedometer Dead
RISONSKI
1995 Ford Contour, 153K miles, 4 cylinder engine. My odometer just stopped working, and the speedometer always is at 0mph, even when I am going much faster. Also, my emergency brake light is also always on, even when not engaged. Does this mean that the other gauges are unreliable as well? And how do I fix the car?
Apr 5, 2007 at 4:54 PM
  • 75,988 POSTS
Speedometer-try checking the vehicle speed sensor
Parkbrake lite-try adjusting the switch
Apr 5, 2007 at 5:24 PM
2CARPRO JACK
  • 11,533 POSTS
Have you checked your brake fluid recently?
Apr 6, 2007 at 1:14 AM
Suggested Repair
Check the vehicle speed sensor for the inoperative speedometer and odometer. For the emergency brake light that stays on, adjust the parking brake switch and check the brake fluid level.
Conversation Summary
A 1995 Ford Contour owner reported that the speedometer stays at zero, the odometer stopped working, and the emergency brake light remains on. Experts suggested checking the vehicle speed sensor, adjusting the parking brake switch, and checking the brake fluid.
