1995 Ford Contour Battery Light On
MERLIN
I have a 1995 ford contour automatic 261,000 miles the battery light comes on replaced alternater replaced battery the light continues to come on after startup any suggestions
Aug 14, 2007 at 3:25 PM
SERVICE WRITER
  • 9,123 POSTS
Make sure all cables are clean and tight.
I have seen many reman alternater bad from the getgo, make sure it is supplying adequete juice. It may be a defect.
Also look at this post:
https://www.2carpros.com/forum/battery-comes-on-vt40233.html
Aug 15, 2007 at 12:32 AM
Suggested Repair
Clean and tighten all battery and charging cables, then verify the replacement alternator is actually charging. Remanufactured alternators are often defective from the start.
Conversation Summary
The owner of a 1995 Ford Contour with 261,000 miles says the battery light comes on after startup even after the alternator and battery were replaced. The expert advises checking that all cables are clean and tight and confirming the alternator supplies adequate charge, noting that remanufactured units can be bad out of the box.
