1995 Ford Contour Battery Light
SHAYMUS47
I have a Ford Contour 1995 with 158000 miles on my 4 cyl 2.0- My problem is that upon acceleration my battery comes on. I changed the Serpentine belt and the drive belt tensioner. I changed the alternator and had the battery and the alternator checked at Auto Zone. They both checked out good. What might be the problem?
May 25, 2007 at 2:29 PM
RUDPRO
  • 224 POSTS
There was a problem with a wiring harness on the Contour where wires would rub or chafe on the subframe, in the vicinity of the alternator. That could be your problem. I think they extended the warranty to 100,000 miles on that problem, but that wouldn't help you unfortunately. I would start inspecting all the wiring in that area, looking for signs of wear or chafing. If you find wires that are worn and shorting out, you'll have to repair them yourself. They sell a variety of electrical tape at the hardware store. Tape any damaged wires individually and tape the whole bundle to protect it. That's all I can come up with.
May 25, 2007 at 4:33 PM
SHELBYGT
  • 56 POSTS
GO WITH WHAT THEY GO ABOVE ME SAID BECAUSE CONTOURS ARE BAD ABOUT THE WIRES GOING BARE AN THE BARE WIRES TOUCH OTHER BARE WIRES THAT CAN LEAD TO SOME MONEY SPENDING THAT COULD BE AVOIDED IF FORD WOULD SPENT A FEW EXTRA DOLLARS ON MAKING THE PLASTIC STUFF THAT GOEN OF THE COPPER WIRES A LITTLE BIT STRONGER
Jul 17, 2007 at 5:54 PM
SHAYMUS47
[quote="Rudpro"]There was a problem with a wiring harness on the Contour where wires would rub or chafe on the subframe, in the vicinity of the alternator. That could be your problem.problem, but that wouldn't help you unfortunately. I would start inspecting all the wiring in that area, looking for signs of wear or chafing. If you find wires that are worn and shorting out, you'll have to repair them yourself.
Thanks that was the problem
Jul 19, 2007 at 11:23 AM
Suggested Repair
Inspect the wiring harness near the alternator and subframe for rubbing, chafing, or bare wires. Repair any damaged wires individually with electrical tape and wrap the bundle for protection.
Conversation Summary
A 1995 Ford Contour owner reported the battery light coming on during acceleration after replacing the serpentine belt, tensioner, and alternator, with the battery and alternator testing good. An expert identified a known Contour harness issue where wires chafe on the subframe near the alternator and recommended inspecting and repairing worn wires. The owner later confirmed that was the problem.
