1999 Ford Contour AC Idle Stall
NICKFLAC
I have a 99 Ford Contour SE... 165,000 miles, automatic, trans, 4 cyl engine.
Car runs fine, however, when I turn the A/C on it revs, then putt-putts, revs, then putt-putts, and then after about 4 times, will stall.
Doesn't happen while driving or giving it gas in park and neutral.
Could this be a fuel filter or fuel injectors?
Thanks!
Oct 10, 2007 at 9:20 AM
  • 75,988 POSTS
Inspect and test the idle speed control motor/valve might not be adjusting the idle for the AC load
Oct 10, 2007 at 9:38 AM
NICKFLAC
Thanks! Where exactly can I find it.... or should I let a pro look at it?
Oct 10, 2007 at 9:59 AM
  • 75,988 POSTS
Below is for 2.0 and 2.5 engines 2.0L
https://images.2carpros.com/forum/automotive_pictures/12900_1999_ford_contour_SE1_1.jpg
2.5L
https://images.2carpros.com/forum/automotive_pictures/12900_1999_ford_contour_ISC_motor_1.jpg
Have a nice day :) www. .com
Oct 10, 2007 at 10:33 AM
Suggested Repair
Inspect and test the idle speed control motor/valve, which may not be raising idle to compensate for the A/C load.
Conversation Summary
The owner of a 1999 Ford Contour SE reports that the engine revs, runs roughly, and then stalls at idle when the A/C is turned on. It does not happen while driving or when the throttle is applied in park or neutral. The owner asked about the fuel filter or injectors, but the expert recommended inspecting and testing the idle speed control motor/valve and provided location diagrams for the 2.0L and 2.5L engines.
