1998 Ford Contour Cold Rough Idle
DH_6783
I have a 98 ford contour and recently since it has gotten colder (40 degrees and lower) it will start just fine but then it stalls when trying to idle or will idle very roughly. During the rough idle all the lights will also become dim and brighter. It has 101,000 miles on it. Any ideas?
Dec 5, 2006 at 3:49 PM
CATCH_15
  • 250 POSTS
Make sure the battery is fully charged and the alternator is putting out sufficien voltage first of all.
Dec 5, 2006 at 4:28 PM
DH_6783
Thanks.......I'll look into that
Dec 6, 2006 at 12:49 AM
Suggested Repair
Confirm the battery is fully charged and the alternator is producing sufficient voltage.
Conversation Summary
The owner of a 1998 Ford Contour says it starts normally in cold weather around 40 degrees and below, then stalls or idles roughly while the lights dim and brighten. The expert recommends first verifying a full battery charge and adequate alternator output, and the owner agreed to check those.
