1999 Ford Contour Rough idle
110,000 MILES • 4 CYL • 2WD • AUTOMATIC
HARDDRIVER911
Hello All,
I am wits end with my car. My check engine light came on and the code was lean engine. The idle started running really rough and my engine died a few times. I have replaced the wires,plugs,tensioner because it was almost falling off, the valve cover gasket it was leaking. But the strange thing is it will idle normally when I turn on my A/C. I was told to check everything from the o2 sensor to the idle air control valve and the egr. I rather not spend anymore money then I should on this problem. I have no vacuum leaks. Any suggestions from anymore that has had this same problem or a mechanic that knows what this could be. Thanks!
Jul 28, 2010 at 6:56 PM
  • 75,988 POSTS
Lean fuel condition could be caused by one of the following below:
1.Vacuum leaks
2.EGR and PCV valve.
3.Low fuel pressure.
4.Dirty fuel injectors.
5.Mass Air Flow Sensor.
6.Oxygen Sensor.
Jul 28, 2010 at 7:45 PM
