Problems replacing fuel pump
MERLIN2021
  • 17,250 POSTS
What color smoke? Black=too much gas, white= head or head gasket, blue= oil. Check your oil dipstick, you may find gas in the oil from cranking the engine without it starting, a new oil filter and fresh oil is needed, also was the fuel pressure tested after the fuel pump was installed? You may need a new fuel pressure regulator. Or the return line is blocked.
Fuel pump pressure is 30-45psi with key on engine off. Fuel pressure and regulator test:
FUEL PRESSURE 1. Visually inspect fuel system, including fuel lines, connections, injectors and electrical connections. Ensure Inertia Fuel Shutoff (IFS) switch is not tripped. Check condition of battery and fuses. Ensure fuel level in tank is sufficient. 2. Turn ignition off. Release fuel pressure. Install fuel pressure gauge. Start engine and increase engine speed to 2500 RPM. If engine will not start, cycle ignition switch several times. Measure and record fuel pressure. For fuel pressure specifications, see FUEL PRESSURE SPECIFICATIONS article. If fuel pressure is within specification, go to next step. If fuel pressure is not within specification, go to CIRCUIT TEST HC in TESTS W/CODES - 2.0L article for fuel system diagnosis. 3. With fuel pressure gauge still installed, cycle ignition switch on and off several times. Record fuel pressure. If fuel pressure is at least 25 psi (172 kPa) after one minute with ignition off, system is capable of maintaining fuel pressure. If fuel pressure is not at least 25 psi after one minute with ignition off, check for leaking fuel injectors or fuel pressure regulator. WARNING: ALWAYS relieve fuel pressure before disconnecting any fuel injection-related component. DO NOT allow fuel to contact engine or electrical components. See FUEL PRESSURE RELEASE .
https://www.2carpros.com/car_repair_video/test_fuel_injection_pressure.htm
Go here and checkout our video.
Friday, October 27th, 2017 AT 2:41 PM (Merged)
THERUGDUMMY
  • 1997 FORD CONTOUR
  • 4 CYL
  • FWD
  • 31,000 MILES
How to change a fuel pump on 1997 Ford contour
REMOVAL
Perform the fuel pressure release procedure.
Remove rear seat cushion.
Remove plastic grommet from floor pan.
Disconnect fuel pump module electrical connector.
Disconnect fuel and vapor return tubes from fuel pump module by compressing tabs on both sides of each nylon push connect fitting and easing the fuel line out of fuel pump module.
Turn fuel pump locking retainer ring counterclockwise using fuel tank sender wrench and remove fuel pump locking retainer ring.
Remove fuel pump module and cover fuel pump module opening in fuel tank.
NOTE: After fuel pump module removal, immediately cover fuel pump module opening in fuel tank in order to prevent fuel system contamination.
Remove fuel pump module O-ring seal and discard.
SATURNTECH9
  • 30,869 POSTS
Service and Repair
WARNING: Do not smoke, carry lighted tobacco or open flame of any type when working on or near any fuel related component. Highly flammable mixtures are always present and may be ignited, resulting in possible personal injury.
CAUTION: Fuel supply lines will remain pressurized for long periods of time after engine shut down. This pressure must be relieved before servicing of the fuel system is begun. A valve is provided on the throttle body for this purpose. Remove the air cleaner and relieve system pressure by using Rotunda pressure gauge tool T80L-9974-A or equivalent and drain the system through the drain tube.
REMOVAL
1. Perform the fuel pressure release procedure.
2. Remove rear seat cushion.
3. Remove plastic grommet from floor pan.
4. Disconnect fuel pump module electrical connector.
5. Disconnect fuel and vapor return tubes from fuel pump module by compressing tabs on both sides of each nylon push connect fitting and easing the fuel line out of fuel pump module.
6. Turn fuel pump locking retainer ring counterclockwise using fuel tank sender wrench and remove fuel pump locking retainer ring.
7. Remove fuel pump module and cover fuel pump module opening in fuel tank.
8. Remove fuel pump module O-ring seal and discard.
INSTALLATION
1. Clean fuel pump module mounting flange and fuel pump module mounting surface and O-ring seal groove on fuel tank.
NOTE: When cleaning fuel pump module mounting surface on fuel tank, use caution to prevent any foreign material from entering fuel system.
2. Apply a light coat of Premium Long-Life Grease meeting Ford specification ESA-M1C75-B on a new O-ring seal to hold it in place and install it into the O-ring seal groove on the fuel tank.
3. Install fuel pump module carefully to ensure that filter is not damaged. Ensure that locating keys are in keyways and O-ring seal remains in place.
4. Hold fuel pump module in place and install fuel pump locking retainer ring finger-tight. Ensure that all locking tabs are under fuel tank lock ring tabs.
5. Secure fuel pump locking retainer ring by rotating clockwise using fuel tank sender wrench until fuel pump locking retainer ring rests against stops.
6. Connect fuel and vapor return tubes to fuel pump module.
7. Connect fuel pump module electrical connector.
8. Install plastic grommet in floor pan.
9. Install rear seat cushion.
10. Install fuel pressure gauge.
11. Turn ignition switch to RUN position for three seconds repeatedly (5 to 10 times) until pressure gauge reads at least 270 kPa (30 psi). Check for leaks at fittings.
12. Remove pressure gauge, start engine and recheck for leaks.
There you go.
68VETTEMAN
  • 1998 FORD CONTOUR
  • 6 CYL
  • FWD
  • 92,000 MILES
Engine Mechanical problem
1998 Ford Contour 6 cyl Front Wheel Drive Automatic 92000 miles
How do you replace the fuel pump on the 1998 Ford Contour and how do you remove the rear bottom seat cushion?
BLUELIGHTNIN6
  • 16,542 POSTS
The bottom part of the seat, is in place simply by two plastic clamp things, just have to pull and fiddle around with them for it to release, they are toward the front and sides of the seat. Now that it's out of the way, follow the rest of the steps below..
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_1936.jpg
ERIC UNEBERG
  • 1995 FORD CONTOUR
Electrical problem
1995 Ford Contour 6 cyl Front Wheel Drive Automatic
How do I remove the fuel lines from the top of the fuel pump so that I can remove fuel pump?
DAVE H
  • 13,384 POSTS
FUEL PUMP
Removal
Tips Click a link to view tip
Tech1FUEL LINES AT MODULE
Release fuel pressure. Remove rear seat cushion. Remove plastic grommet from floor pan. Disconnect fuel pump module connector.
Clean area to prevent contamination in fuel tank.
****Disconnect fuel lines from fuel pump module by squeezing tabs on fuel line together and carefully pulling fuel lines from fuel pump module. *****
The lines are difficult to remove but they will pry out as long as the tabs are pushed in. Use a large needle nose plier, straddle the line fitting use a pry bar
under the pliers and pry upward to pop out the lines.
Using Fuel Tank Sender Wrench (D84P-9275-A), turn retainer ring counterclockwise and remove retainer ring. Remove fuel pump module and cover opening.
Installation
Ensure fuel pump and mounting surface is clean. Lubricate new "O" ring with suitable grease. Carefully install fuel pump module into fuel tank. To complete installation, reverse removal procedure. Pressurize fuel system and check for leaks.
ABCDEFGHIJKLMNOP
  • 1997 FORD CONTOUR
  • 4 CYL
  • FWD
  • 150,000 MILES
1997 Ford Contour 4 cyl Front Wheel Drive Automatic 150000 miles
Dont know how to remove fittings off the top of the fuel pump to release the fuel line so I can get the pump out
  • 109,885 POSTS
Disconnect the fuel lines from the fuel pump by compressing the tabs on both sides of each nylon push connect fitting and easing the fuel line off the fuel pump. Let me know if this helps you.
STEPHANIEHEN26
  • 1998 FORD CONTOUR
1998 Ford Contour 4 cyl Front Wheel Drive Automatic
I need to replace my fuel pump but can't get the fuel lines disconnected. How do I do this?
  • 109,885 POSTS
Are they the quick connect lines? If so, there should be a horse shoe shaped clip that holds it in place. Remove the pin and it should disconnect.
COKITO
  • 2000 FORD CONTOUR
  • 4 CYL
  • 165,000 MILES
Engine Performance problem
2000 Ford Contour 4 cyl Two Wheel Drive Automatic 165000 miles
I need help to replace the fuel pump, this model has the fuel pump under the rear cushion. I see 2 conexions but I dont know how take out.
Friday, October 27th, 2017 AT 2:42 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
Removing access hole under rear seat will not help. This only allows access to the wiring and fuel line for returnless system. Have to remove the fuel tank if you are replacing the fuel pump.
TREESES
  • 2000 FORD CONTOUR
2000 Ford Contour 6 cyl Automatic 106500 miles
I recently had my fuel pump replaced in the car. When I next filled the car with gas the gas began pouring from the bottom of the car. I took the car in again to be fixed. This time the car held the fuel, but every time it gets to 1/4 tank the car begins to violently shake and stall out. When I took it in to get looked at the mechanic told me he couldn't find anything wrong... So what is going on?
ANDY
Mine is doing the EXACT same thing. Only I havent changed the fuel pump yet. Do you also have a problem with 7 gallon of fuel filling the thing up?
2CP-ARCHIVES
  • 4,540 POSTS
  • 1996 FORD CONTOUR
  • 180,000 MILES
I have a 96 Contour Sport that is running rough and stalling in park and all through driving range. I have replaced the fuel pump, several fuel filters, coil pack, plug wires, plugs, and rebuilt the injector wiring harness. Sometimes it will start and run fine for a few minutes. Then it seems that the engine is starving out for a second, start to stall, then the rpms shoot up, transmission catches and it continues on. It will do this for several repeats, then run normal another few miles. Also, if I don't shift to Neutral at stops, it will almost certainly stall and take several attempts to restart. I am at a loss for the cause, and this being the daughter's college car, I would like to get it up and running well.
  • 52,797 POSTS
Is there any codes in the system? We need them
sounds like more of a vacuum leak than any of the other parts you through at it.
You should have someone look at it for you as it sounds like you are frustrated. Get a second opinion then you can repair it with confidence
Friday, October 27th, 2017 AT 2:43 PM (Merged)
