1997 Ford Contour OD Light Flashing
MR CONTOUR
1997 ford contour 4 cyl 185000 kms. i am a newbie here and i am sure question has been asked before is there a simple solution to prob. with 97 contour o/d light flashing and transmission shifts hard(i have to let off gas pedel to shift to next gear it is a auto transmission! any help appriciated
Mar 3, 2007 at 11:50 AM
TAURUSWHEEL
  • 718 POSTS
If the od light is flashing, it usually indicates there's an issue within the trans..take it to a locally owned reliable trans shop for diagnosis, they'll be able to scan it for any codes...
Mar 3, 2007 at 12:31 PM
Suggested Repair
Have a locally owned, reliable transmission shop diagnose the vehicle and scan for transmission codes. A flashing overdrive light usually indicates an internal transmission problem.
Conversation Summary
The owner of a 1997 Ford Contour with an automatic transmission reports a flashing overdrive light and hard shifting that requires easing off the accelerator. The expert says the flashing light usually indicates a transmission issue and recommends diagnosis and a code scan at a reliable local transmission shop.
