1999 Ford Contour Engine Won't Start
DBURRIGHTTHECF
1999 Ford Contour, 23,000 miles, Not sure of engine size. My wife was backing out of the yard when it sounded like she was dragging a chain down a gravel road for a couple of second. At that point the engine died. I was able to take the car out of reverse and put in in nuteral to push the car back into the yard. When we turn the key, all of the belts turn, park plugs fire, and everything in the car turns on, but the engine will not fire. I am wanting to fix this problem myself, but I do not know what the problem is to fix. Any help anyone?
Oct 17, 2007 at 8:32 AM
BLACKOP555
  • 10,386 POSTS
first i want to eliminate weather it is a engine problem or a system problem like electrical or fuel have a fuel pressure and volume test performed and post the results back here.
Oct 18, 2007 at 1:02 PM
Suggested Repair
Have a fuel pressure and volume test performed and report the results to determine whether the no-start is an engine problem or a fuel or electrical system problem.
Conversation Summary
A 1999 Ford Contour died after a brief dragging or grinding sound while backing up. The belts turn, spark plugs fire, and accessories power on, but the engine will not fire. The expert recommends a fuel pressure and volume test to distinguish an engine problem from a fuel or electrical system problem.
