1998 Ford Contour Won't Start
STEVEIE06
I have a '98 for contour with 189 000km on it. Car won't start. Can not hear starter trying to start car and there is limited power to things such as brake lights, head lights do not turn on, wipers, radio won't turn on either. Dashlights do not turn on. When you turn key to the #2 accesorie position there is no air or no warning lights that turn on. When car dose start everything works for about 24hrs, then everything stops working, spedometer, odometer. tripometer and all warning lights. A mechanic said it could be ignition switch, alternator has been replaced, i am thinking it is starter and ignition. any ideas???
Feb 9, 2006 at 3:11 PM
PEPPERMRJ
  • 1,158 POSTS
I believe it is the ignition switch also.Does the key tumbler feel sloppy? Replace the key tumbler and ignition switch.
Let us know.
Feb 10, 2006 at 4:08 AM
Suggested Repair
Check whether the key tumbler feels sloppy, then replace the key tumbler and ignition switch.
Conversation Summary
A 1998 Ford Contour with 189,000 km will not start and has little or no power to lights, wipers, radio, and dash indicators in the accessory position. When it does start, gauges and warning lights work for about a day and then fail. The alternator was already replaced. A mechanic suspected the ignition switch, and the expert agreed, recommending replacement of a possibly sloppy key tumbler and the ignition switch.
