1997 Ford Contour Door Won't Latch
LADLEBUGS
1997 Ford Contour LE - 2.5 liter engine - 128,000 miles - Driver side door won't close unless I'm outside and can push it really hard with my foot. The locks work fine. If I close the door with the lock off, the door will swing open and will not catch at all, but if I lock it first it will catch but not all the way. At least that way the door doesn't swing open when I'm driving. It acts as if there's something caught in the door (like when the seat belt gets in the way) but I've checked and can't see anything that would block it. I can close it all the way if I'm standing outside and use my foot to close it, but then have to climb over the console to get to the driver's side. This just started last night and it's not cold enough to blame it on the weather. Help!!
Feb 21, 2007 at 4:09 AM
2CARPRO JACK
  • 11,533 POSTS
Check the door striker . See if it has moved inward... if so loosen and readjust
Feb 21, 2007 at 4:21 AM
LADLEBUGS
If you mean the little thing that moves back and forth in the door, it moves just fine.
Feb 21, 2007 at 4:35 AM
NOS
  • 320 POSTS
he means the pin that sticks out of the door jamb.not the door itself. it sound to me like you need a new door lock assembily. the jaws are not staying locked when you close the door. 8) NOS
Feb 21, 2007 at 5:46 AM
Suggested Repair
Inspect the striker pin on the door jamb and loosen and readjust it if it has moved inward. If the latch jaws will not stay locked when the door closes, replace the door lock assembly.
Conversation Summary
The owner of a 1997 Ford Contour says the driver door will not latch unless forced shut from outside. Unlocked, it will not catch; locked, it catches only partway, while the locks otherwise work. Experts advise checking whether the door-jamb striker pin has moved inward and readjusting it, and suggest the door lock assembly may need replacement because the latch jaws are not staying locked.
