1996 Ford Contour Electrical Issues
MACATAC0
IS THERE A FUSE THAT GOES FROM BATTERY TO ALTANATOR ON A 1996 FORD CONTOUR? IS IT IN THE CABLE OR WOULD IT BE IN THE FUSE BLOCK ALSO MY OVERDRIVE LIGHT THAT COMES ON WHEN OVERDRIVE IS NOT ON QUIT WORKING AT THE SAME TIME THE TEMP GAGE QUIT AND TO TOP IT OFF THE LIGHTS THAT SURROUND THE KEY HOLE ON THE OUTSIDE DOOR HANDLE WILL NOT GO OFF.... THINK ANY OF THIS IS RELATED, OTHER THAN ALL BEING ELECTRICAL??? :roll:
Dec 3, 2006 at 4:20 PM
BRUCE HUNT
  • 3,754 POSTS
Just making a stab here but this sounds grounding related.
Dec 3, 2006 at 11:24 PM
SHELBYGT
  • 56 POSTS
i dont think the fuse does exsit but like the guy said it could be ground relted promblems and check all of your fuses
Jul 17, 2007 at 6:18 PM
Suggested Repair
Check all fuses and inspect grounding connections. A separate battery-to-alternator fuse may not exist; the simultaneous electrical faults point more toward a ground problem.
Conversation Summary
The owner of a 1996 Ford Contour asked whether a fuse runs from the battery to the alternator and whether it is in the cable or fuse block. At the same time, the overdrive light and temperature gauge stopped working, and the exterior door-handle keyhole lights would not turn off. Replies suggested the fuse may not exist and that the related electrical symptoms are more likely a grounding issue, so all fuses and grounds should be checked.
