1998 Ford Contour Stalls After Freeway
RICKWRIGHT
my 98 ford contour, 64k miles, 4cylinder automatic stalls at idle (engine just quietly dies) after high speed freeway driving, acts as if it timing is off when I try to restart it(kind of shakes and shudders) and/or it is out of fuel. After waiting 20 minutes or so, it starts fine, runs fine, sounds fine until the next stall out. I had the fuel filter replaced, Spark plugs replaced, chemical cleaning of injectors by mechanic and it still stalls after freeway driving of 30 to 40 minutes. No check engine light comes on when it happens or after it happens..engine temp gauge is normal. What do I do now?
Mar 20, 2007 at 4:13 AM
  • 55,746 POSTS
The problem you discribe can be many things, but here are some thing you want to check, First try putting the trnamission into neutral when you come off the freeway, if the engine keeps running its the torque converter clutch not unlocking like it should. Next, you need to have a fuel pressure gauge hooked up to see if you loose fuel pressure, and finally, try running your car with the EGR valave vaccum line disconnected to see if the egr valve is sticking open causing the car to die. Please let me know, thanks for visiting 2Carpros.com
Mar 20, 2007 at 9:45 AM
Suggested Repair
Diagnose the stall after freeway driving by shifting to neutral when exiting the freeway to check whether the torque converter clutch is not unlocking. Also test fuel pressure for a drop, and run the engine with the EGR valve vacuum line disconnected to see if a sticking-open EGR valve is causing the stall.
Conversation Summary
A 1998 Ford Contour with 64,000 miles stalls quietly at idle after 30 to 40 minutes of freeway driving, then restarts poorly until it sits about 20 minutes and runs normally again. The fuel filter and spark plugs were replaced and the injectors were chemically cleaned, with no check engine light and a normal temperature gauge. The expert recommended checking the torque converter clutch by shifting to neutral, testing for lost fuel pressure, and disconnecting the EGR vacuum line to check for a sticking EGR valve.
